And one question came up, do i need a second Arduino for the Hydraulic lift?
with easy solution yes:
you install machine control and connect to D3 D4
and also possible more complex to do and t use:
by modify litle bit the arduino code with auto steer module using Uturn sequence link to this kind of discussion:https://discourse.agopengps.com/t/rear-linkage-steer-module/3462
Okay thanks
I do not see same problem when using Autosteer_USB_4.3.10.ino on my system. It show the numbers in the same screen as you have **steer module not connected.
Try disconnect (in AOG Serial Ports ) - then scan for ports- when “new” port is ready (COM5 or something)- then click connect again.
otherwise I get same problem as you.
no the **steer module not connected is still there
There are more than one Autosteer_USB_4.3.10.ino with same name but different date, so make sure that the one you use is from latest support folder download.
On my system I can both use Autosteer_USB_4.3.10.ino and maths Autosteer_USB_4.3.10_BNO08x.ino
no no guys we have a big misunderstanding. I am using the version, DanielP has recommend on Dec 20. So it is the Autosteer_4.4.10.ino. Sorry maybe i explained my problem not clear enough. So i am now pretty sure it is a bug. Everything i tested works fine.
It’s beta code, you can’t expect it to work stable like the last release
