So you changed 1000 to 100? Did you use send to save it?
Constellations may depend on your location: In Europe you would probably choose GPS+GLO+GAL
Yes, it was 1Hz - 1000ms. I changed and saved. Now the question is, what’s wrong with this configuration file that it doesn’t set it to 10Hz?
I have to try to upload these configurations again and see what frequency will be set.
Edit:
Reloading this configuration the roverortner changes the frequency to 1Hz. Maybe I have a bad one, however, these configurations … Maybe someone will throw what to upload?
try this
simpleRTK2B_FW113_rover.txt (20.9 KB)
In video I did not see you select any file to upload, so it uploads the one used last.
Your file uploaded to this thread earlier, gives 10 Hz here!
The one from SjaakA does 10 Hz too
But probably not the constellations i want because it only gave me float instead of Fix with my base over Ntrip
When you upload the config are you sending config to f9p or saving config from f9p. My first time I saved config which replaced the correct rover config file
No, as you can see in the movie, I’m uploading the - >> GNSS file, so it should be fine. Tonight I will try this second configuration.
But not an impossible thing. If you at the beginning had selected the correct unzipped file, and then by accident touched the wrong button, then it is just overwritten.
The file we see in your uploaded zip some posts ago is that your own file that you made a new zip of?
Or one that was already zipped?
I downloaded it from this link I gave it, unpacked it and uploaded it.
I solved the problem. The error was in the file I was loading. I downloaded the same file, but not to the tablet, but to the computer. Unzip it with winrarem, I uploaded it and it’s good. Probably the problem was that on the tablet, the windows explorer was damaging it when unpacking it.
hello everybody
the tony files work fine : only for radio communication between base and rover
here is a text file I made to help : way to configure f9P ; load files and be sure to save at the end
for beginners and for those like ,old enough to forget anything
UcenterGuidePour naviguer.txt (1.5 KB)
