Thanks Juan, I am thinking about tracing that wire back a little to the axel at the other side of the tractor to sensor, there is a square plug on our 6130r (hopefully doing it this way I don’t have to take the mudguard and cover off).
Did you just disconnect the standard plug and plug in the one connected to PCB?
Or do you leave the plug in and splice the wires? So both tractor and Agopen PCB are connected?
you can follow the cable to the SSU, and connect directly there, as I did, the connector in the photo was under the cabin, my recommendation is that you connect directly, do not make a T. you can burn something, since you would have 2 power supplies energy, Stock and AOG.
Where is the SSU typically located? Under the side console?
under the cab in a combine
i dont have john deere tractors but i can go look at a couple that are brand new just give me a few days
