I really like this 2 improvements. I use BNO and latching on-off button with led on official PCBv2 board, and the wire to connect them are are spread all over the board: which does not facilitate their connection. With your improvement it’s possible to use JST XH connectors ?
Do you thinks it’s possible to do the same with one Batt In pin & ground pin grouped both and one +12V Out & ground grouped both in order to use connectors for Batt In wires and +12V Out toward 12V/24V converter wires ? Connectors likes JST JFA J300 serie (available in 3.81mm or 5.08mm pitch).
Wow very nice with the 2 twin pads !
What the pitch of the pads ? 3.81mm ou 5.08mm ?
No particular suggestions : in fact I was looking for connectors that can fit on the official PCBv2: so I search in JST website by pitch of 5.08mm. Not a lot of choice, the only connector available with a 5.08mm pad and current rating >10A that the search engine proposed to me was the J300 serie.
But du to the pad arrangement on the official PCBv2, it’s not very convenient to use connectors, so I abandoned the idea and went back to screw terminals for this PCB.
So I haven’t check if JST J300 serie is easy to find and order, easy to assemblate (does it require a very special and expensive crimping tool ?) and the price…
But with your new PCB proposal, this kind of connector solution becomes interesting again.
Cool it fit into the 3D printed box I have design for PCBv2 !
Hello KAUPOI.
Congratulations on your work and thank you for sharing it.
Can you tell us what the differences are between your PCB (v3) and Brian’s v2.
Thank you.
