Hi, I have a v4.5 standard pcb that I was planning on using a phidgets motor but have yet to purchase the motor, cytron etc, I have seen a few using the keya motor and it looks like a lot neater install but I have a few questions.
From what I read it can be used on older tractors that don’t have can bus, is this correct?
Is it as simple as supplying 12v to the keya and then connecting pin 16 on Ampseal to CANH to and pin 17 to CANL, flashing teensy using AOGConfigOMatic with Keya motorwheel?
Would it be RVC only or non-rvc?
My understanding is I wouldn’t need a cytron if using Keya motor?
I’m just checking my logic as if the above is correct it sounds a bit too easy ![]()
I have tried joining the keya motor aog telegram group but Im getting the invite link has expired, I am joined agopengps-international no problems.
Are there any disadvantages of the keya compared to a phidgets motor and gears?
Sorry for all the questions but I want to check my logic before ordering keya and finding out it cant be used as I think.
