We need several languages translated. Here is the excel sheet.
Now it is VERY fussy to be able to put the translations back into AgOpenGPS so there are some rules.
Do not change any columns other then making the column wider you are working on, and the default one so it is easier to read. Never delete any rows or columns or reorder them in any way - or it will not import.
When you post back here, post as a txt file, AOG_513.xlsx.txt so it can be posted since we can’t post xlsxl files directly.
Before you start, be sure you fully understand how AgOpenGPS works.
Languages needed are Italian, Polish, and Ukranian.
Modify the filename to include your language you edited when you post back. Later we can add more languages once these are translated as that is another big process. Thank you!
See below for most current
