My vehicle build is entirely electric which may be an factor but has anyone else had a problem with passive USB port hubs?
I’m using a laptop with two USB ports and I need four:
Autosteer PCB, ardusimpleRTK2b board, relay and Raspberry Pi. Whenever I deployed the vehicle, it would randomly lose power to the ardusimple board causing all kinds of fun.
Thought perhaps the Pi was the culprit, so removed it and tested with just the PCB and ardusimple; same result. Added a powered USB hub and the problem went away.
Has anyone else had these power issues before? Anyone else using a passive hub to power the RTK2B and the autosteer PCB?
