Looking for photos of WAS fitting? Specifically on NH T6 if possible?!
Have a look to this: User baraki
Tm165 supersteer
Tm165
More easy but angles are maybe not so good
Here’s one on a T6030:
Thanks for the detailed Pictures, may I ask why you used an additional linked arm and didn’t connect the first arm straight to the axle. I’m trying the same on a Claas Ares 696 and was wondering that.
So that all the angles that it has to bear do not affect it. In special variation on camber a angle.
So you mean to even out SAI and Caster like discribed in another post from you ?
Vili, could you share the .stp or .stl files with us?
No angles are already fine to be installed in the fender support, follow the king ping. It is so that when turning the efforts that the sensor supports are less. And Camber have a variation 10º.
Has anyone fitted a delphi sensor to a new holland t6.155 with a non suspension axle
