Setting up the steer settings, the motor turns even with min PWM is at 0. The slider does alter it, as ot gets slower as the scale decreases…but still moving at 0!
Trying to figure out what you are doing.
So autosteer is still on.(Because according to pic on telegram you have made freewheeling mod to cytron, so it cant be off)
And pwm is down at konstant zero(which mean you must be parked)
24 v you could possibly have two different GND points .
Then perhaps no problem.
I run hydraulic so can’t test your situation.
Try to find reason: set it at zero again and measure volt diff between your GND points.
