MT765B installation
We have a steer ready 2003 Challenger MT765B (two track Cat), we’ve used its built in autosteer and an old Autofarm via some sort of can bus translator. Should one of the can bus firmwares work on it? Which one?
Did you get this going? we have a steer ready Mt765E looking to add agopengps to it.
Not yet but from my research the can bus firmware should work
After flashing, open the serial monitor:
Send S to open the service tool, then set Brand 9 (Cat MT Early).
Set Panda mode and the baud rate to match your F9P.
Apparently there’s a connector here with red 12v, black ground, yellow can hi & green can lo. The 12v power is not enough to reliability power in all-in-one with GPS receiver
Thanks my MT 775E is different, I think the top 9 pin is the diagnostic J1939, maybe pins F and G from another thread? Is it just the one can bus we need for steer and WAS?
Here’s a snippet of a telegram conversation I had with people who know more then I. I’m told everything should be on one bus but you might need to select a different “brand” according to the bus you connect to.
Patrick Imhof:
I have a challenger mt655C, this one uses brand 1 I think, but I’m pretty sure yours would use a different brand.
Matthew Elias:
It looks like the v4 can bus ino should work, I have selected early Cat and Panda 460800. Likely won’t test for another month.
Ryan:
Mt6xx is just a Massey wheel tractor so you are correct with brand1, the 2 trac machines should be brand 8 or 9 i think. There is the later one and earlier models, think if the 700B has the proper translator software the later brand setting should work if you connect the pcb to the isobus of tractor. The older setting is for if you connect the pcb to the j1939 of the tractor
your valve is on the ISOBUS I think there’s a sticker there and maybe the 3P DT plug has the ISOBUS (Steer bus)
Thanks for that. I found the cab circuit diagram for 775E. Five buses on those three connectors.
Power train, ancillary, light/aux, isobus, and cat datalink. So probably a bit of
trial and error with brand and isobus or powertrain
The circuit diagram for the MT7xxE confusingly does not follow the physical order. which is actually CAT ET (top), AGCO EDT (middle), and ISO (bottom) see also training manual picture from another thread. note that the top connector has no keyway so is not the standard 9 pin Deutsch with keyway on center pin.
It’s not that much trial.
We know its on ISOBUS. So that’s given.
The brand is 2 choices. (CAT Late or Older)
AgLeader has a doc how to set up the “translator module” to accept 3rd party guidance. That needs to be done.
