No imu from micro v4.5
I am setting up my new board. I have the teensy firmware flashed, imu and cytron on the board. I was using GPS guidance for the past 2 years so I was going to use my f9p through its USB connection. As I am setting up my steering wizard, I see I have no roll compensation. Is there a way to get this to work?
Why not put the f9p on the board where its supposed to be and run it all via ethernet
As said on telegram, use Rx tx on v4.5
Thank you for the info. I did connect to the rx and tx for the first f9p spot. I pulled the 5 v from the xbee spot on the board. This is working great. In my first test run in the field I was able to hold the row straight within 3". I have more work to get my planter ready for planting but will run more tests either tomorrow or wednesday. I will try to post a video once it is all functioning.
