Not connecting to caster - network not switching
This is my first try of a 4.5 board + ethernet (+ keya) all set up as per config-0-matic
All seems to work perfectly when the tractor is in range of the office wifi but when I go out of range it’s not switching over to mobile connection - this is a Panasonic FZ-G1 with LTE connection on-board and all worked perfectly when the panasonic was just talking serial to F9P so I think it’s probably a simple networking setup fix - but how?
Does it connect to LTE at all?
I had to do a registry mod on the Toughpad that is using it’s own SIM card instead of WiFi hotspot, cant find instructions I followed at the moment though…
Maybe this? Network NTRIP issues on UDP
your tablet is showing no internet!!
2nd pic bottom right corner
so its not a aog issue
This morning, the first thing I tried was simply to turn off wifi, but windows still tried to get to the internet via ethernet → gateway rather than the mobile connection.
So I added the IgnoreNonRoutableEthernet registry hack, rebooted, but that made no difference.
Pull the ethernet plug - internet via mobile worked, insert ethernet plug - no internet, so I realized I needed to get rid of that ethernet gateway, but Windows would not let me delete it in the ‘new’ network settings.
However, I eventually found I could delete the ethernet gateway in the old school ipv4 settings and that fixed it - ethernet for udp comms, mobile for nTrip
