OpenGradeX
[OGX V2.4.8 ] ](GitHub - BlackAceIndustries/OpenGradeX at 2.4.8)
I have 20 antenna boards available, for those interested. Anyone trying it that has used previous OGX will need to update everything as there is a communication change, as I have converted it to JSON.
Wow looks fancy. You have a video of some of the features? :face_with_head_bandage:
One thing I’ve been wondering about a feild with 5 ditches how can you tell where they are in relation to your position. I thought of dropping flags with names so you can tell which cut to load for which ditch but I can’t find where to input a name for a flag.
I can probably look to add all the field cuts to the main display for that purpose at some point in the future. To those trying as well the NTRIP is currently a mess and barely functional. I use radio for my correction so haven’t put to much work to it. I am sure there is also lots of outdated info in the repo, that I will work to update now that the snow seems to be on its way.
A few questions I have…
Can I use still use this for simple ditching(survey, cut)?
Do you have controller boards as well?
Is there a parts list anywhere?
Can the OpenGrade X connect to any GPS other than your Boards?
I have a fork that I’ve started modifying to work with AIO PCBs, it’s not ready for release yet.
As in a non f9p or an all together separate AOG board?
just any GPS receiver that can ouput NMEA to a serial port. Like a Deere StarFire
The new boards I have coming have an rs232 chip on them. The code that relays the gps data to OGX is pretty simple and just kind of cheats in knowing the order the gsa, gga, and vtg arrives from f9P and doesn’t do a lot of checking so I could see a problem potentially there. I think it’s a pretty easy fix, would just require a bit more parsing before being added to the message and sent to OXG.
@BlackAce Having issues getting data to show up in V2. Just clarifying… github doesn’t have a config for the Rover F9P. Is the old one supposed to work? Also wondering if there is a setting to keep the Sim in the middle? When I start turning the “scraper” goes off the screen.
EDIT:
Never mind I all of a sudden remembered these board I built I mixed up TX and RX!
There have been some changes to the f9P configuration, baud rate to 230400 and the GSA message is enabled.
Hey BlackAce, what’s the state of this project? Got any boards for sale?
I saw you mentioned dual gps and two scv control, are those both functional? NTRIP still a mess?
Would like to incorporate my pull grader behind quadtrac which has separate control on L and R side of blade
