The F9P is the same, but there are different pheriperals on the boards.
I’m using the ublox C099 F9P Board, it won’t work with a ardusimple config.
I do my config manually.
Which board do you use?
Try out to use u-center to show the actual configuration:
Improved konfiguration files for f9p with firmware 1.13 - GPS / RTK / GNSS - AgOpenGPS
Don’t forget to store changes in the flash memory
