PCBV2 Switch wiring issues
If you have selected pressure or current switch be sure that the cut off value is high enough, above the reading.
It’s just a momentary push switch
When I have selected either button or switch in the steer settings config and sent it to the module, I was expecting the icon to turn yellow immediately? Only after if there was a fault in my wring or swtch then it might just not turn green?
What should normal operation be? I have it cycling between yellow and red by pressing my button or switch.
PROBLEM SOLVED.
