6.4.4 release review:
#improvements:
AB Curve calculation
AB Curve recording options
Shutdown AgIO and option to shutdown machine from AgOpenGPS automatically
Shutdown option if powerstate goes to battery (ignition on/off)
optional hardware messages in AgOpenGPS (depends on hardware if applicable)
GPS Output updated with roll corrected position
AgIO UDP connection form simplied
turn off autosteer if position jumps more then xx cm (setting)
PurePursuit form simplied and look aheads changed to Steer Response. Speed gain an Aquire slider removed. Automatically controlled now
Deadzone for steer angle (to calm down motor if angle error is below xx degree
border around the GUI with red color if RTK Fix drops
headland form rearranged
new Steer Angle Bar option (in addition to XTE Bar) for visual guidance
new GUI for steer Angle bar
new XTE number texture with changing color to orange if XTE is higher then 4cm
small other GUI improvements
#fixes:
AB Curve Numbering
version label in AgIO
Ntrip source table button disabled until return from searching table
tracks Menu now vertical
only show Hydraulic lift button if it’s enabled in settings
Sim Box fixed
version text now change text color when go to dark mode
pass direction triangles updated and better visible
if minimize AOG when autosteer is on, maximize again. OGL needs to be on screen to work properly
pass number and offset now center top under XTE number
Aquire to hold mode swap now >20cm XTE
tram button position
And a lot of other small tweaks!
Please try, and post bugs in the Telegram Bugs topic or on discourse!
