@MylArti :
Thnk you very much for your config, I’ve removed glonass from m8t outputs and in rtkrcv and added by the same way beidou. I’ll see if fix is better …
@ikidd
What is exactly your config ?
Have you verified with ucenter that you have RAWX and SFRBX frames and that both serial (at 115200) and usb outputs are activated ?
First try to send ubx on rtk2go, it’s straightfroward, i’ve indicated the command (after you can test rtcm output from str2str, I’ve never test that)
francois
