RTK reciever nd antenna sugstion
Hello!
I am new here and i have just recived my PCBs ( V4.5) from JLPCB and now i am looking for reciever and antenna. I am looking at the ardusimple website but i can not decide what configuration to chose. My objective is to have the simplest configuration to run because it will be used by varrios operators and to have RTK in order to use the tractor for planting corn and sun flower.
Can someone advise me on what configuration to chose?
Not sure if v4.5 boards are micro only, but theres 2 types of receivers. People usually buy this kit:
and this IMU:
Teensy 4.1, cytron and WAS you can buy on aliexpress cheaper:
Lots of info here on software and hardware.
Thank you for your reply. Do i need to set a base for the gps?
Also it is probably cheaper to source things like the teensy and BNO from other sources.
If you’re wanting to use RTK, and there isn’t another available base station in your area, then yes.
