using AOG for documenation for fertilizer speader
tinkered with the section control to make my Rauch MDS drawing the worked area in AOG
The data transfer is via WiFi UDP, so only power is needed. The actuall Section control code supports 2 independent networks, so it will fit with 2 tractors. If you need to adust the settings later on you can do in webinterface.
I use the ESPDuino (Arduino UNO shape) because it has a very good power regulation for 5V and 3.3V. You connect it directly to tractors 12V and it boots allways (others have trouble sometimes).
Solder the switches to GND and 2 GPIOs (e.g. 21+22 = SCL+SDA as they are near the drill hole) add 2 1k resistors from the GPIOs to 3.3V as pullups. Connect the LEDs with resistors to 3 GPOIs (15,33,32) and the power in via fuse to the jack.
It uses the section control code with settings:
2 sections, relais: yes (for LEDs), switches: yes (for the microswitches), no Main switch, no rate stuff
parts:
ESP32 here ESPDuino (Amazon ARCELI D1 ESP32)
2 IP 67 micro switches (conrad 704655)
box (hammond box C conrad 501262)
2x neodym magnet 32x5mm
LEDs for WiFi and 2x sections
5x 1k resistor for LEDs and pull up
1A fuse with holder (conrad 501262)
cables + connectors (WAGO 221) + power plug + velcor to stick PCB to box …
