Section Control for sprayer
Hi everyone,
I made a 7-section section control box using an Arduino, and I posted a short demo video here:
This project is largely based on MaxVD76’s SectionControl_AgOpenGPS project:
I mainly modified the code to make it compatible with the latest AgOpenGPS version 6.8.5.
I hope this can be useful for others working on a similar DIY section control setup.
Do you have a list of things you need?
Yes, there is already a parts list here:
Basically, you will need an Arduino and momentary switches, type (ON)-OFF-(ON). This is important: do not use switches that stay in position, because the code needs a short 5V signal, not a permanent signal.
You will also need 10k ohm pull-up resistors for the buttons, 220 ohm resistors for the LEDs, a relay module, and a 12V to 5V voltage regulator to power the relay module.
Can you give me code to Arduino nano?
Coupure_troncon_V0.9.9.ino (37,9 Ko)
Here is the code.
