Hey
im sure this has been done but i cant seem to find what the best way to set this up? do i need a separate power for the gps?
Hey
You need to explain exactly what you mean as āsetting up gps over ethernetā isnāt really a thing.
Have been using agopen for gps only- however it seems to consistently loose connection randomly. If I unplug the usb and reconnect it it works again for a short while. Only thing I can plug this doing to is the usb connection is unstable so was going to change it to work via Ethernet
With which PCB?
I think hes got no pcb, only f9p and usb cable.
You need an arduino uno and rj45 shield to achive what you want. But I would rather go for any AIO pcb.
Yeah thatās correct just the f9p, itās more about the Ethernet being more stable with vibrations.
Use the search icon at the top of the page.
There are some interesting results with ā'ethernet F9Pā
