Simplertk-udp link
Hello, I want to make ardusimple rtk over UDP, I have the converter in the photo, can I do it?
sam
Set f9p uart1 settings to same as tcp232 serial. Set f9p uart1 to the correct nmea output. Set tcp232 to the correct UDP settings. Wire it up.
Thanks to you, I was able, thanks.
