Do you have a single antenna and use reverse direction?
We need some help figuring out why some have issues and some do not at all.
So if you could please answer these simple questions it would help a great deal.
- Does reverse detection work well for you?
- Where is your antenna mounted? Front of cab, over front wheels etc
- What is your Start Speed set at? (In the Config/Data/Single Antenna Settings)
- What is your Trigger Distance set at? (In the Config/Data/Single Antenna Settings)
