The WAS I solder to some 3 wire 18awg belden cable, then to a short connector harness that plugs into the NAV box.
Currently working on a 3d printed steering quick tach system, the motor to wheel portion needed a more broad approach.
The air ride sensors are tough as nails, the aliexpress ones are cheap and plentiful.
I was dredging out some muck and mud over the axle forced the arm to buckle in. Removed the pivot bolt and reset the arm back, no harm was done. Next summer have a linear potentiometer to test, it may have more resolution but doubt its tough as this type.
