Switch Mode: Servo to disengaged the Clutch Mecanisn of steering with ACS712
by context
-ACS 712 can check the current consomption of the motor and with AOG we can define a limit to stop autosteer
(chosse and ACS 712 with correct lin up in our case 5A range is ok for most of us)
-Switch mode is mode in AOG that start the autosteer by activate and stop by release our sensor/switch
Today   when  we use the switch  mode  with ACS712
It is not possible   to  stop autosteer because the switch is  engaged .
In my case the switch is in motor bracket and after mechanical coupling the autosteer start .
Manually we need to disconnect the mecanism to stop autosteer .
-Adding an ACS712 cannot change the scenario with actual configuration of ino file and i want to unclutch the clutch mecanism to get free steering wheel and deliver this task to the servo .
The servo is equiped with wire in shape of slot that permit only to disengaged.
The power is taking care from 12 v to isolate from Nano ( but you can do test with the 5V of the board )
On Board D5 is PWM port available and necessary to drive Servo directly
i put info in this video
Code here github
 The  target  is to  continue to use the clutch manually  with safe  unclucth in case of
czy można podłączyć pod pcb aio v4.5std ?
