What’s the correct 2x3 ethernet header for the teensy board on a v4.5 board?
I ordered what was listed in the wiki but it’s got the same female connection on the v4.5 board (female connection) so they obviously won’t connect
That header is for ethernet and is absolutely needed. They need to bridge an extra long gap so standard 2mm headers won’t reach. You can solder the female header to the bottom of the teensy and get a set of the short male headers and use them to bridge between the two headers. Or you could pull the pins out of regular 2.54mm headers and push them through the teensy and solder them. Or you could go to digikey and buy the extra long 2mm headers.
Thanks. I pulled pins apart like you suggested. Seems to be working. Thanks
