Installation credit goes to my little brother
(Iām doing much better with google than the drill
Weāll wash the tractor later this week but this shouldnāt really receive any water here.
We ended up using a longer arm (Iāll upload the STL laterā¦)
And the 2nd batch of sensors needs the āpinā/shaft rotated by 90 degrees.
I strongly suggest to buy 2 female + 1 male ā you can add an extra connection to the CAB just in case it has to be removed.
Sensor itself: https://www.aliexpress.com/item/1005004979692332.html?spm=a2g0o.order_list.order_list_main.65.2f771802YOYqS1
3D printed stuff:
WAS Assembly stl_step_f3d.zip (753.0 KB)
Update the new TPS sensor needs a 45 degree:
WAS Assembly stl 45degrees.zip (153.7 KB)
