I trying to get autosteer to work, but i cant get the steering wheel motor to turn. I have a imu and wheel angle sensor thats working. I can see the output in agopengps. I can even drive the motor with the testbuttons on the motordriver.
I have tried:
Using the drive functionality on the steering gui.
Connect a GPS an try opening a field.
Enable the autosteer in software (green steering wheel)
Enable the autosteer by connecting steering switch
They are connected, but have you upload the “Autosteer…ino”.
Also read the manual. Also check you switch(you have one switch on PCB and one for the autosteer.
Yes, i have uploaded the config, first time with the Xloader, second and last time with arduino IDE. But im afriad that i have fried the nano, im awaiting shipment with 2 new nano’s in a few days.
You can check the two switches. The PCB switch on and your pcb diode will lighten and compass will become red. The steering switch on and the compass becomes yellow
I have uploaded the autosteer ino only with IDE
There is a setting for how to activate autosteer. Button or on screen aka manual. So what happens when you press the autosteer icon at buttom right?
Icon just right to compas icon
Nope, but when i messure the connection beween D3 and D4 on the nano, there is connection between them. So the motorcontroller does not even try to turn the motor.
Purple compass means that the AgIO does not recognise a steer board is connected, even if one is physically connected. The steer switches (either in the GUI or a switch connected to the board) won’t do anything until the program is talking with the steer board.
Check the steer module com port is connected in AgIO.
