The pin on the arduino is D9?
Pin D6 to ground,
And you can solder switch before resistor and other wire to ground and you will bypass opto.
It seems like i find the issue. When i connect the D6 to ground the autosteer works. So the issue is between the arduino and the steerswitch.
I could write a book about PD6 ![]()
Also try to resolder the middle pin of the steer optocoupler, it does not have much solder, looking at your picture of backside of the PCB
