And what messages are all outputting to usb?
Iām at 1 hz, and IIRC its just the default messages plus UBX-RXM-RAWX:
Can I disable all those NMEA messages and just use the RXM-RAWX for the PPP data? I plan to do a fresh RTKBase install after I finish this so assume the settings will all be reset during that process anyway.
Update: Tirns out RTKBase records the logs itself so center not necessary
I donāt think you need the nmea
Hi eveybody, Iām trying to make an AIO board and when I go to configure the microFP9, I donāt know how to load the file, because the microFP9 hasnāt got usb plug
Anyone knows how to do it?
Thank you
You need to plug it into a pcb like this
Yes, I have that board, but Should it be powered to configure de microFP9? I presume that the microusb plug in front it is just for configureā¦
It needs 12v power on pin 22 of ampseal connector, pin 23 is ground,
Yes usb is for configuration.
