In the NTRIP settings,in Agio allow messages to go through UDP
Or Network NTRIP issues on UDP
Thank you! That was it, I had to turn on UDP under the NTRIP position tab. It’s currently in float, but I had fix for a minute. (Not too surprising I can’t get a solid fix right now. The receiver is currently outside the house in a blizzard. Now to button up the box and install a hydraulic valve on the tractor.
Thanks again, I couldn’t have done it with out you guys.
Had my baud rate for the port set low. Bumped it up and now have solid RTK fix ![]()
Disconnect your COM port.
Yes disconnect com: IF you have any red dots in this screen, click it so they are all green (Green is Able to make connection, but not activated )
Thank you, I did turn com port off now. All are green.
