WAS and having to keep replacing them
I was wondering if anyone has had this issue? I am now on my 5th WAS and it doesn’t work also. I get a new WAS and test it on my tractor before i install it and it works. Once i install it in place, down by the wheel and get it hooked up it will not work anymore/can’t get it to read. I have my 5V at the WAS but no signal back. I have replaced the wiring between the sensor and the control box. I have taken the WAS back to the control box to test it but still not working.
What was are you using and how you install them?
Is the pin out correct
Have a look here and double check the pinout on the WAS plug. Sometimes the plug has a few variations and some pins need swapping
Thanks for the reply and sorry for the late reply. It been a while since I have been able to get back to this. I have went through two A-Premium Ride height level units and one Germban 06380-HN2-305 unit.
Both type of units were mounted to the axle and the arm or pin (germban) was mounted to the hub section. All three had extra room to move so i didn’t use all the strock.
Thanks for the reply and sorry for the late reply. It been a while since I have been able to get back to this. I have went through two A-Premium Ride height level units and one Germban 06380-HN2-305 unit. The unit i used only had the three-pin connection. I will give that unit a try.
