Hi all,
Today I am trying to configure my system, after configuring the WAS, it is still measuring 38 degrees one way and 28 in the other. Visibly the wheels appear to be turning the same.
I am using PCB v4.1 with a single GPS. I am also using the land rover sensor for my WAS
Possibly the steering stops are set slightly different creating a big angle the one way.
As long as you have the was as close to zero when straight ahead you should be good
