5 volt Pressure Transducer
I have a similar setup with a 5volt pressure transducer on valve, is this code working with your setup now? How is it wired into your PCB board. Thanks
Yes, I have it working. I tweaked the trigger amount a little lower to make it work better. I have it coming into the ads1115 marked aux 2 on the side of the PCBV2. In the code it has to be ads.readADC_SingleEnded(3) however since that’s where it actually ends up on the ads1115.
This is the INO I currently use.
Autosteer_USB_for_V4_–_Modified_By_Slimfarmer_on_3-25-2020.ino (20.4 KB)
I modified your code to this to be able to adjust the sensibility of the steering disengagement by the pressure transducer with the encoder setting in Aog is this correct
//modif le 22/03/21 ====================================================
if (aogSettings.ShaftEncoder)
SteeringWheelPressureReading = ads.readADC_SingleEnded(3);
SteeringWheelPressureReading = (SteeringWheelPressureReading >> 3); //bit shift by 3 0 to 3320 is 0 to 5v
if ((pulseCount >= aogSettings.PulseCountMax)||(SteeringWheelPressureReading >=(aogSettings.PulseCountMax*100)))
steerSwitch = 1;
currentState = 1;
previous = HIGH;
looks promising. When version 4.6 comes out ill have to try it out. 1300 or 13 with the conversion in your code seemed to be a good amount for my setup. I look forward to trying it.
Cheers
Hello, I got some questions on this 5 volt pressure sender . I got the V2 board running on UDP V5.6 software in a nano. I am steering a old hydraulic cat challenger I can’t find and info on what pin the signal go’s to to reference the pressure in AOG , I got one set up with a simple pressure switch ( it trips the switch when you turn ) but it works very poorly on the encoder input as when you grab the wheel it closes the switch , it is not a pulse till you let off the wheel. So AOG just keeps steering, but humans tend to keep steering and not let off the wheel . I tried to look through the Adruio ino code to determine what pin could do this or that but I am still lost . My other plan was to use a 555 timer to drive the encoder input so it would see a pulse instead of a constant voltage. But it seem like a lot of stuff to add if this sensor input works. By the way I got a Tennsy driving PANDA over UDP also. Any advice would be greatly appreciated
As far as I remember, you set the number to zero, instead of 1
Well maybe I should try 0 I will see what that dose
I probably remember wrong, if you can connect to other side of the pressure switch. Also read the answers in this thread.
Hi, I’ve retro fitted an AOG to a Hardi SP Sprayer. It had a Eaton Vickers valve on it which I have working well but it has the 3 wire 5v Pressure transducer for kick out. I thought I’d just change out for a switch as mentioned in this thread way back in 2020 but did notice that there was a pressure turn sensor option for the steer cancellation. I assume this is to use with a pressure transducer? If so, how would wire to the board and do you have to change any code? Jumper on pressure side, not remote I guess? All-in-one v4.2 standard board.
No code change needed, put jumper to pressure, and it should work
I’ll need 5v supply, ground then 0-5v signal. The Ampseal pinout is for a grounded switch. I can use the ground but I’d need to get a 5v supply from somewhere.. maybe grab it from the WAS supply or the GPS supply? Will pin 10 Remote/Pressure accept the 0-5v signal if the jumper is on the pressure pins?
I used WAS 5v supply and pin 10 for sensor, switch jumper to pressure, and used pressure sensor in AOG setup
