Are you using “normal” autosteer while standing still? Then no 12 v!
If you use the manual steer setting in expanded autosteer setup, then you should have 12v.
excuse me, I don’t understand
Perhaps this can guide you Autosteer basic configuration
I press key 1 which turns green but pressing arrows 2 nothing happens.
Excuse my English (google translator)
Do you have 12 V on 6/2 valve (pin 7) when key 1 is green?
And you have pressed the send to send setup ftom AOG to PCB (teensy )
No, not 12V on pin 7
Most farmers in Europe are asleep at this time
Yes, switch
No, not all !!!
I don’t know if that has anything to do with it, but the remote control via pin 8 does not control the GPS engagement, the “steer” LED lights up but that doesn’t change anything on the screen.
Have checked out the video training? I believe this is covered in the operations video.
https://www.youtube.com/playlist?list=PL1N2N2XFHWW1fIDhb7koOa7hxH0LGppYc
What letter is next to autosteer toggle icon is it M(manual) or R(remote)?
Are you supplying ground to pin 8?
Over steer switch…
yes, the “steer” led on the pcb lights up,
Are dir, pwm and gnd soldered(3 header pins on cytron). Cant rly tell from picture…
