I’d better start saving as I really like all the new features especially the improved steering, tramlines and boundary curve. It’s absolutely brilliant thank you.
One small problem is that I can’t seem to change Min Unapplied.
Also is there a reason why in section control I can’t seem to get Off(secs) to be larger than On(secs)? My sprayer takes longer to stop spraying than to start.
Thank YOU to develop group.
I like the graphics, easy to understand without text, but I would prefer more difference between the two green colors in the button for autosteer configuration.
Maybe a bug when using a normal keyboard. when pressing space (after last word) cursor jumps to start of line, space can be made in middle of word, as seen in Number 1Tractor.
This does not happen when using screen keyboard.
If typing this: Same silver, then it will look as the saved vehicle here.
Maybe it is because I have these letters on keyboard ÆØÅ
found something, not sure its a glitch or even really a problem.
I was playing with a field learning the in and outs of making boundary’s and AB lines,
Then I changed the implement width and reduced it to one section instead of 3. after that all the painted lines showing the ground I already covered lost a butch of area. the area that the calculator in the top corner was still right but as you can see in the pic the old painted area’s are very incomplete.
Also, I coudnt find where you could change the angle of the already made AB lines?
Also if I had to request one more thing it would be that there is more green or red showing on the steering wheel and u turn icon, just to see at a distance with a glance to know if its on or not. maybe the square behind the symbol change color?
Thanks to all of you putting the work into getting this right! I am really looking forward to autosteer this summer.
You are saving an actual file name so the characters are limited to windows filenames valid characters. For giggles here is the mutex excusion string to kick you out if entering a non compliant char. I will check the spacebar though, that is odd.
Actually AOG accepts scandinavian characters, I suppose the Windows language files take care of it.
But the keyboard is different so space might be changed.
Made a field boundry, and used auto u turn to skip 1 to the end then 0 for first pass back, then back to 1 skip to fill in . On v4.3.10 for some reason, when I would go back through the field to fill in the skips, it would turn just past half, then make a quick back and forth jump, then finish the turn. That doesn’t happen on the beta, it is one smooth turn.
Zooming with a mouse wheel feels a bit backwards. Wheel up zooms out and down zooms in.
When I import a field from KML-file. Simulator sets longitude to 0.0000.
For my opinion implement could have an another measurement. The actual thing usually happens a one or two meters behind the wheels (pivot point). Like sprayer or spreader.
I will see what is up with the sim in the set sim. If a field is made from kml - or if just loading a field you don’t need to set the sim anymore. I guess i just never used this screen even once yet. I better try it out.
First try today.
I found a little obvious bug: There is a new button at the bottom which can show tramlines/wheels at the main symbol? I don’t know yet what it is really for, but right-click on it shows the same ‘flag-color changer’ like on the flag button.
