You might find some useful hints here.
If you type puma in search (magnifying glass) at top right, you can find more help.
Look for connector under left cover (behind passenger seat)
Will you be ok?
Good ![]()
Works fine! Tomorrow I will try to connect to Fendt. Thank you Tony.
Im currently also building a system on a Case Puma 200, nearly the same age as yours.
In my Case I removed a Trimble fm-1000 System and started a Agopengps build. I left the Harness with the Connector for the NAV Controller in the Tractor, but I didnāt want to cut of the connector so i layed new wires in the Tractor.
I disconnected the wires going to the Orbitrol, and made my own wires which i routed in to the Cab.
I connected the Steering Valves to the Cytron and GND, and the Main Valve to block the other two on 12 Out and GND on Brians PCB. In my case, when i flip my switch to activate the Relay on the PCB, the Main Valve gets powered so i can steer.
The WAS:
I Unplugged the Connector, on the Right side of the Radiator, Removed the Original Connectors and build in Deutsch Connectors, with another cable going to the Cab. I found out how to wire up my WAS with a Multimeter, when measuring the Resistance.
Thank you very much for the information, I have read several of the topics and it has clarified me a lot. I will continue to report progress and ask questions!
I see that it is difficult to use the cables that come out of the valves and the angle sensor, I think it is a good option to replace them with new ones and not touch the ones that are pre-installed. Then connect them as indicated in the agopengps schematics. Thank you very much for sharing your work, letās move on.
@CVX.
I should make a simpler diagram for T6, where I Don 't shift wires in connectors.
That way security relays and the original autosteer switch still works.
In my first diagram I wanted to ONLY use wires already in steer ready tractor.
EDIT: Can be found in my onedrive, get link in success stories: new-holland-t6-175-year-2018
I was able to run my Fendt 933 without any problems. I did not test in the field because it was raining, so only a hall test with simulator turned on and manual control, but it seems to work well. The lessons in the initial posts came in handy, I could easily check that the communication was working properly and fix any bugs. @common rail is a very good teacher, thanks a lot.
Thank you Tony (@CommonRail) for the fast answerā¦but unfortunately our arion dont have this can idā¦Do you know if only claas tractors which are Gps ready have this Button activated?
I cant imagine that claas uses diffrent can IDs for the Same Joystickā¦
Do you know then CAN ID from the F Buttons from your aaxion ? SSo i can Check if this can id is existing at our arion. (maybe can id of the f7 Button or so?)
The can Id that Tony suggested is only on the steering canbus so if the tractor doesnt have the autopilot valve then you dont have the steering canbus. You would then need to look on the tractor canbus to try find a message from the button and I would think itād be a different id
how do I have to connect the BNO08x to the Arduino?
BNO085 5volt or CMPS14
GND - GND
SDA - A4
SCL - A5
VCC - 5v
BNO080 3.3volt
GND - GND
SDA - 330ohm - A4
SCL - 330ohm - A5
VCC - 3.3v
The 3.3volt version you have to check, heaps of people say it works fine with the 330ohm resistors but you are best to use a level shiter. The otherday somebody else just added some pulldown resistors to bring the 5volt pull up back closer to 3 volts
I did use 330ohm in serie to A4 and A5 and pulldown resistor for Bno080 to arduino ![]()
Which WAS are you using?
Iām not sure which to buy.
That depends on how you want to use it.
Direct on the king pin?
Or with a connection rod?
Mainly you should choose one that at least use 90 % of its scale, the way you mount it.
Ackermann can be compensated in AOG program, but also something to be aware of.
If you type : angle sensor, in the search binocular at top right, you will get many suggestions.
If your CAN steering are steer ready tractor you do not need to buy a WAS, itās already in the tractor ready to go.
Are you trying to steer your Valtra T4?
Yes you are right. The first time I tried I already got a WAS Signal but now I donāt get one. I only changed the Arduino. Is this right?
seems to me that you dont have right COMport? COM10 and not COM3?
