I did not consider mechanical wear on the steering parts.
I did not understand the spring loaded drag. Have not seen these worn out and from the drawings I would assume wear at the king pin area would not cause a significant angle change. After all it is the angle between the top part of the king pin and the front axle. That angle should not change a lot if wear allows the king pin to move somewhat. Perhaps it does, as said, no experience about wear on our tractors.
A bit different tractor on your drawings, which one are they for?
Fendt B168 mechanical drawing
14500 ish i think. Dismantling has uncovered kingpin wear too. It doesn’t add WAS errors directly but does add side load to the WAS which accelerates wear indirectly.
My Drawing is correct for the tractor. 2010 820.
Testing the 724 on can bus again later hopefully :clap:. With revised code to use AOG’s gain etc.
@CommonRail out of curiosity we currently run older New Hollands which if my understanding is correct with their links to trimble and encoding of data are more difficult to access. We may be looking at a new tractor soon and in addition to New Holland could be considering a Valtra due to good relations with the dealer. Do you think that Valtras as part of AGCO would be more accessible on the CAN Bus system, similar to fendt and MF, than New Holland? Although this wouldn’t the main deciding factor in brand the tractor would come autoguidance ready and would be great to use that with AOG and other homemade electronics.
CAN0.sendMsgBuf(0x8CEFF02C, 1, 6, data);
0x8CEFF02C is not a valid extended CAN-Id. It should be 29 bits long not 32, or did i miss something?
Where did you get info about the protocol/commands?
The short simple version is New Holland steer ready machines have installed a standard PWM valve and WAS in front axle, from there you can connect your own 3rd party steering controller. (Factory / Trimble system in New Holland have the steering controller in the Nav controller witch is not in steer ready machines).
Valtra use a standard Danfoss PVED-CL like the Massey Ferguson, its not really anything to do with Agco products, more just what systems the Manufacture uses.
You are correct that is 32bits long.
So convert it to Binary, take 29bits from Right to left. Convert that from Binary to Hex and see what you get? (CAN-ID)
Take the 4bits on the Left, Convert that from Binary to Hex and see what you get? (Priority)
I think thats the simple way?
Had an extended drive around one of my frozen maize fileds tonight. Nice and bumpy and no IMU to smooth them out. The 724 ( via can bus with code using AOG’s PWM output to alter steer) was extremely well behaved. Really smooth steer and most surprising, headland turns were REALLY good.
Got two more BNO085’s ordered but the suspense is killing me so I think my 716 might loose it’s BNO085 tomorrow!!
Still got things to iron out in the code but it’s way more than promising!! :sunglasses:
I am sure i wont matter, as the library will send 29 bits anyway.
only 3 priority bits according to standard.
data[0] = 5; data[1] = 9; data[2] = steerState; data[3] = 10; if (steerState == 3){ data[4] = setCurve; data[5] = 152; }
I am very interested in how this data structured. Are you able to provide more information?
Nice, ive got two more BNO085’s on order too. You will know more than I do but i was using the set steer angle from AGO and map that to suit can message, not the PWM? Ive got visions of the steer board only containing a Nano, a CAN Shield, and a BNO085.
That is what I did first but it was very savage on rougher ground. So what I’ve done now is run a steer variable to mimic the steer angle then drive this steer variable up and down with the PWM value. Then I map this variable to CAN. I’m taking the WAS figure from can and, when the CAN isn’t steering the tractor I map the WAS value to the steer variable so even when not autosteering it always tracks the steering. This prevents big jumps when steer is engaged.
Hope that makes sense!
As for the PCB, yes, nano, can unit and BNO is all we need really.
Is it possible to run two can adaptors from one nano?
I’m thinking headland management…
[edit…]
I very much doubt I know more than you do! I know what I want my code to do but a catalogue of schoolboy errors frustratingly slows me down!! I’m getting better, i think! :grimacing:
Is there a brand you work with? You have quoted the Fendt message witch is different to the standard ISO Danfoss system. With everything I make my own rule book from experience as i go until there is a proven more simple method.
The Danfoss books in the CAN-BUS section here are sort of OK if you have a rough idea of whats going on.
I’ll work out how to explain / show my rule book tho.
I know exactly what you mean, and i thought straight away ā€œhes onto something thereā€ haha.
You can run two CAN adapters, you just run separate CS and INT pins. Can0 & Can1.
It is also possible just to run a second nano with output pins controlling inputs on the first (More for remote engage etc from the arm rest)
Why you need two CAN adaptors? Are not on the same network?
Exactly, direction is Vbus, button and command are Kbus. 2 separate CAN bus.
There are 4 CAN systems on my 724. V-BUS, K-BUS, G-BUS and ISO-BUS. As @Tooki57 the joystick and associated controls are on the K-BUS.
[Edit… This image is actually more appropriate]
BUS1
:flushed: I didn’t know, I learned a new thing :+1:
I’ve learned more from, and as a result of AOG than from decades of being interested in Ag technology. :+1: :sunglasses:
If your reading this subject and interested I hope your CAN shields / test parts are ordered because all this talk is only just the start of more too come…
This is a very poor video of the 724 steering a headland turn via can-bus on very rough ground, with no IMU. (hence the heading instability)
Seems to stick to the curve a lot better than my other (wheel motor) system, even on just bouncy fix to fix!
… and if you noticed the odd bend in the worked area, this is why!! :joy:
Sus scrofa?
