If you mean the service tool from the teensy, yes.
Its on valtra/massey (1) and panda 115200 (p)
what frame number are you controlling? cAD131C?
Can you steer the wheels in both directions?
I am controlling CAC1C13. Directly from Tonyâs code
When I activate the steering in AGO, the wheels turn to the center.
no matter where they were before.
itâs no true!!!
frame â0xcac xx xxâ is frame back from PVED valve
controlling frame is â0xcad xx xxâ. What frame number you controlling give me a full number (id).
im sending 0x0CAD131C and receiving 0x0CAC1C13
in 0x0CAC1C13 im only receivig this data
| ID | LENGTH | D1 | D2 | D3 | D4 | D5 | D6 | D7 | D8 |
| 0CAC1C13 | 8 | 128 | 125 | 0 | 255 | 255 | 255 | 255 | 255 |
| 0CAC1C13 | 8 | 128 | 125 | 80 | 255 | 255 | 255 | 255 | 255 |
| 0CAC1C13 | 8 | 128 | 125 | 16 | 255 | 255 | 255 | 255 | 255 |
D1 and D2 should be the current WAS.
D3 is the valve state.
correct?
correct!
soo, it looks like something is wrong with the sensor or the wheel angle sensor wiring.
Check the voltage from the sensor. Maybe itâs broken!
the dealer repaired it 4 months ago because the âspeed steerâ was not working because there was no was signal. now it has a was signal again, and the âspeed steerâ is working. the handler has calibrated the WAS
Do you know where exactly I can measure the sensor?
@CommonRail Tony wrote at the beginning of this thread
So then to steer the tractor, there is two simple steps:
- Tell everybody on the CAN-BUS you are the navigation controller and you are alive.
- Then send non stop at approx 40-80msec intervals the desired set curve, and if you intend to steer or not.
From there the steering controller (tractor) will the tell you (the navigation controller), What the desired set curve is, What the current curve (WAS) is, and if it is ready for steering commands or not (manual lockout etc).
Is it possible that I still have to do this âactivation sequenceâ?
hello @CommonRail in the HH menu
Ch1 and Ch2 should both be yes or only OSPE valve (YES)
if i have CH2 (nav controller present; to yes - getting error code 15993)
or should CH1 only be (yes - OSPE pressent)
sensor is connected to the PVED.
Does this mean that the sensor he replaced (in the axle) is not involved?
i donât know
Hey, Does anyone have a all in one triple can pcb they want to sell i cant seem to find anywhere with all the right parts etc.
i am wanting to steer a fendt 924
Where in the world are you?
new zealand
I can send anything you need, just send me a message.
Bonjour Commonrail, jâai un Fendt 724 Profi + que je souhaite autoguidĂ© via le CAN, jâai dĂ©jĂ achetĂ© un PCB4,5 et je voudrai savoir quelle carte teensy 3 CAN acheter pour piloter mon tracteur ?
dâavance merci. Cordialement Phil
PCB4.5 has a CANBUS on it already. Also, you should ask questions in English here, otherwise you assume someone else will translate it for you.
How I can engage autosteer on massey 7624.
Everything else working fine. But tractor own headland button dont work. Can someone point me right direction.
