From fivefinnishfarmers topic:
"Normally in the factory when autosteer is installed they switch the wire coming from WAS to the other plugged connector at the steer ready harness. From there the signal goes directly to navcontroller(X716) and maybe the navcontroller sends WAS value forwoard via canbus… "
Maybe this explains why serial says CAN-bus and wires don’t?
I think they changed to canbus autosteer around 2019 2020.
The 2018 N H t6 175 autosteer ready, I made AOG autosteer on in 2021 had canbus hydraulic output block at the back.
I’d use an AIO board.
Power WAS from it then splice the signal connection so it goes back to the factory ECU (that way the differential and auto 4x4 still works)
You’ll likely need the lock and cytron output to control the valves.
Disengage on a similar Magnum was in the steering column. I had to supply 5V and it pulled it to ground.
On that said magnum I was able to find the button on CANbus, but we decided with the operator that a pedal would be nicer for him as he’s using the hand throttle.
I think AIO will fit in the same place as you found those connectors.
