Somehow I have damaged one of my two CMPS14 from Robot Shop by removing the pin header and putting it on the other side of the pcb so that it works to plug into my modified KaupoiMod pcb.
If I run an I2C scanner on the Nano with only the CMPS14 connected, it finds nothing with the damaged one and it finds a device on addr 0x60 with the working one. The damaged one also does not blink the onboard LED.
Can’t see anything wrong.
No idea where to probe onboard to see if it’s a connection issue at the pin header, the only info I find is the pdf on robotshop’s site which doesn’t include a schematic.
I’m only testing my two cmps14 boards with this jumper, one plugs in from the bottom and the other from the top. The unchanged one works, the other doesn’t.
I doubt soldering killed the board. But it’s entirely possible a stray electrostatic discharge while handling the board could have done it. I’ve killed things this way before.
The F18325 IC has 4.66 V from pin 1 to 14 (USB voltage, same as pin 1 & 6 on the connector). The vReg has 3.3V right at the regulator so I think ground and power are connected. I’m thinking that even if the other connections had ripped paths/vias it should still light the LED at power up like the working cmps14 does.
Unfortunately, I don’t have a schematic, F18325 is PIC16F18325.
According CMPS14 datasheet, LED blink (Pin 5 of PIC controls the LED) on startup and show I2C adress.
Chek MODE pin, it should be VCC (I2C mode)
According to the diagram, the PIC16F18325 IC provides the i2c connection, one end of the LED is connected to LDO (5volt), the other end is connected to the other end of the LED with a resistor from pin 5 of the integrated, 18325 seems to be broken.
