Hi everyone,
I’m having some trouble getting AutoSteer properly tuned on my CNH tractor.
I’m using a Keya CAN steering motor , Standard AIO v4.5, UM982 and BNO085 IMU.
On flat ground it works quite well. It’s not perfectly straight and doesn’t hold exactly 0° steering angle all the time, but the deviation from the A/B line is usually within ±2 cm , so I’m pretty happy with that.
The problem starts on uneven ground. The tractor begins making unnecessary left-right corrections and sometimes oscillates around ±10 cm from the line.
What’s strange is that when I use the steering test mode and set a fixed steering angle, for example 0° or 4°, the Keya follows it very well without any noticeable oscillations. But as soon as I switch to A/B line guidance, things get much worse on bumpy ground.
I’m using the original CNH WAS, powered by the tractor’s 5 V supply. Looking at the steering angle graph, the signal seems quite stable, and I haven’t noticed any obvious spikes.
I’ve already tried different Gain, Min/Max and Reactivity settings, as well as Roll Filter at 0 and 2, without much improvement.
I’m wondering if the problem could be related to the BNO085, Roll Compensation or IMU/GPS Fusion settings , rather than the steering motor itself.
Has anyone had a similar problem, especially with CNH tractors? What Roll Compensation and IMU/GPS Fusion settings are you using? Could the original 5 V WAS supply cause problems even if the measured angle looks stable?
Any suggestions on what to check next would be appreciated.
Thanks!
