I take it both gps and auto steer are plugged directly into your laptop.
What type of gps are you using? for example I use emlid m2, if I do not use the higher amperage usb 3.0 port and a heavy usb cable for it it has power issues.
Are the leds on your gps staying stable when you plug in the autosteer?
              sorry    make  a copy sreen of  AGIO  and  device manager,
voice and  speech  never replace a schematic  or photos
                CoNe
                    3 August 2021 08:54
              24
              When I connect autosteer port, then GPS signal is lost, and when unplug, GPS signal is back. LEDs are ok. On Arduino, Tx is blinking, but Rx not.
              You need the right config on your F9P
    Here are 2 config files for f9p with my config worked out with ardusimple team.
config for base station with msm4 messages at 1 hertz - usb output
baseortner.zip  (3,8 KB)
config for rover (agopengps version)
roverortner.zip  (3,8 KB)
10 Hertz
GPS-GLO-BEIDU-GALILEO
SBAS DISABLED
output to USB and GGA to uart2
gga+vtg at 10 hertz
Firmware download at ublox
[U-Center Software](u-center
Be sure to save the config after uploadig.
After the upload, the F9P should send only GGA and VTG.
                CoNe
                    3 August 2021 09:58
              26
              How to upload .txt files into F9P via U-blox?
              thanks  for picture
you are using  V4  and    you load   V5.ino
so  it is  not good      you need  to    put  same  software on arduino and AOG
as advise   please   use  the V5.2.2…
                CoNe
                    3 August 2021 10:11
              28
              First, thank you for your effort, I’ll update, because this is actually v4, you’re right.
I have no F9P here at the moment but you do it here.
                CoNe
                    4 August 2021 12:50
              31
Have you uploaded this code ( program ) into Arduino nano? AutoSteer USB v5.0
Min configuration
              yes  this  the   arduino program    for  NANO  plug in   USB  and   compatible  with V5
                CoNe
                    4 August 2021 18:17
              33
              It is for max configuration? I set min configuration, so that’s probably reason why it doesn’t work.
              Sorry  i dont  understand    there is  no max and  min  it is unique  config
you need to update  this prog  and  AOG    will  configure   after
so  now  that  you load  it   start  AOG  V5 …
                CoNe
                    4 August 2021 18:42
              35
              Min configuration means I don’t have accelerator, inclinometer and gyroscope etc. I have only WAS and other nessecary components.
              no problem!
on V5   all   this are  replaced  by  CMPS14  ou  BNO080-85
if  you dont have  it   one  of them   AOG  ignore  it
lets  go to start  V5
and  configure your  com port
                CoNe
                    4 August 2021 18:52
              37
              COM ports are ok now, it’s connected. The problem is that Rx led blinks slowly which means that Nano is receiving data, but Tx blinks very fast, different than Rx. On older version, there was written “not connected BN055x…”. Also, how to know that Nano sends data to motor?
              could  you make a copy screen  of AGIO?
                CoNe
                    4 August 2021 18:59
              39
This happens on older version.
Data in V5.
              since  now  forget  V4
and  V5 seem  working
now  step by step
For GPS   what  are the version?
For  Autosteer board  the   Was   seem  not  working   did  you  apply  12v  to the board ?
                CoNe
                    4 August 2021 19:09
              41
              Applied 5V on Nano and WAS, and 12V on IBT2 motor driver. I don’t know what you mean for GPS version, but I think all is newest version. RTK board simplertk2b was configured to send only VTG and GGA messages, too.
