COM ports, AutoSteer configuration problems
for GPS i consider this config Ublox F9P - Config for rover - #74 by m_elias (nneed also to update to 1.13 be carefull)
for autosteer board to understand more clearly coul you take a picture of your board …
in official V2 board the WAS receive 5V from 5V regulator and not nano …
AutoSteer board is not same as Arduino Nano? If not, does it include all ( nano, motor driver etc)?
16281048706251494646022151828917
Thanks it is more clear
but you are missing ADS1115 I2C converter
the was is connecting to this
Ok, I was reffering to this schematics : http://www.gh-ortner.com/agopengps/lib/exe/detail.php?id=start&media=autosteer_switch_minimum_config.jpg
I thought it’s enough, as it is called minimum configuration.
agree but since V4 AD1115 is necessary
this file is too old 2019/01/06 23:45
sorry you need to purcharse this I2C component to go forward
I have that convertor, but first of all Thank you for your effort to help me! I’ll mount it tomorrow and tell here, so you can see when you check messages. Greetings :slight_smile:
your welcome!
farmer helping Farmer !!
I’ve completed autosteer system, and it’s still not working (same as it was before). I checked Arduino nano pins ( D5 - PWM, D6 - DIR) with oscyloscope and there is no any signal. When I move WAS, program recognizes it. Autosteer and work switches are directly connected to GND, steer enable was set to None in AOG. Here’s some autosteer settings
did you apply the configuration AOG to nano by send ans save ?
after go to steer setting to play
to do a simulation try to calibrate artificially and normmaly with steer switch to the ground the electric motor need to work according Was potentiometer position
check the topic of Brian here
or this video ( sorry in french ) about config of autosteer
Ok, I’ll check this topic and video.
WAS and I2C communication works, and I guess I got it. But communication of Nano with motor driver is suspicious as motor simply doesn’t work. WAS data changes as I set potentiometer in different position. Also, in video you sent, I could set steer properties if motor works, but it doesn’t. Nano is receiving data but suspect that doesn’t send (Tx blinking rapidly, same when it’s not connected).
if WAS data change in AGO it seems NANO working
to be sure did you send data fron AOG to nano by the screen :wink: image
try to change all data in steer configuration to be sure nano receeive some info
in drive mode   check  PWM  value   on screen
PWM is 120 and on some moments it is 0 and again 120.
and when you play with potentiometer ? ( be sure you are in drive mode tractor icon need to be green )
Then PWM goes to 35 or 39 or 57 in some moments, but usually stays 120.
in drive mode ?
the motor never turn?
put a LED/resitor to one output of nano to see if it is blinkink
Yes, drive mode is on, and also autosteer is on.
Motor doesn’t turn.
I set LED to motor driver so it should blink when AOG sends instructions to motor, but it doesn’t blink, I could send photo where LED is.
IMG_20210806_130206
sorry blinking in PWM is complex for human to sse
but if it is lighting it seems you get the signal
