Converting Fileds and Lines fron AOG to ISOXML
Now this is new. I can create the field in AOG open in GeoBird to create Wayline and export into ISO-XML33 file and then import the ABLine into AOG.
Here is a file if any of you want to try to load it in one of the commercial systems.
TASKDATA.zip (8.7 KB)
I’m a bit embarrassed but I don’t have AgOpenGPS running on any computer or tractor just yet. Been a while since I was using it. Does it store kml files by default for each field? Are the boundary and ab line files separate?
Yes. Each time the field is closed the kml is built. Each feature is separate and you can save each in GE as its own entity (kml.)
So one kml file created per field? multiple entities in it? I’ll have to fire up AOG and get an example file created. Then I’m sure I can make a converter script using my existing isoxml code.
That looks really good! I’ll test your task data and see if my Fendt can process it.
If I understand you correctly, you took a field file from AOG, imported the KML file into QGIS, created a shapefile there, and then uploaded it to Geo-Bird. Is that correct?
No, this was exported directly from AOG.
You can load most any kml boundary into AOG. Or draw it inside of AOG.
I let GeoBird find the best path and imported it into AOG.
Yes, one file. Boundary, lines, curves, recorded paths, and sections are all in there.
Okay, that’s interesting. My last test’s with the AOG KML in GeoBird didn’t succeed. It could be possible that I have a layer for coverage and some AB and courve Lines. Maybe that is the issue, why I get an error.
I do have some AOG kml files here. I’ll make a python script to convert it to isoxml sometime tonight. Should be fairly straight forward to adapt the isoxml code I posted earlier.
Here’s a rudimentary converter. It’s command-line only right now.
Invoked with something like:
python3 kml2isoxml.py "Field Name" path/to/Field.kml
On windows use py to invoke instead of python3. By default it creates a TASKDATA directory in the current directory. Passing -h to the script will give you a list of options including setting the operator, farm name, and full output path to write the ISOXML data.
Currently only does the AB Lines and Boundaries in a single Field.kml file.
This weekend I’ll put a simple Tk GUI on top of it and make it so you can point it at the AOG Fields folder and it will grab all the fields and put everything in a single TASKDATA bundle.
Hey!!
We are working on importing fields from ISO-KML to AOG right now.
Sweet! Because I didn’t want to tackle the conversion in that direction myself! I assume we’ll see isoxml export as well at some point? Very slick!
Version 3 is not too bad, all in the taskdata file, but version 4 is a lot more complicated.
Good progress on ISO XML. AOG can import v3 and v4 (and maybe others) iso files and create a field from them.
When you close the field, every field no matter how it was created, it creates v3 and v4 TASKDATA.xml files.
Hopefully can release this LTS version very soon
I am eager to see if this ISO XML option will work to import my lines into a Raven Viper 4! What is an estimated timeline on this release?
I want to input a bunch of lines manually using Lat/Lon and heading. While playing with the latest version 5.8.3, I notice that when entering values for an AB line, only the on-screen keyboard works for that. Can this be changed to allow input from a keyboard and accept copy/paste?
his would by far be the simplest and fastest solution.
Could you check before the release whether this also works in simulator mode on the home computer?
I don’t want to touch the version on my tractor anymore because the system is running very well at the moment (never change a running system…). I would perform the conversion at my desk by pulling copies of the field files from the tractor and then opening and saving them once in the simulator.
p.s. Thnks
I have a success to announce!!!
All of my fields and meadows are now converted and deposited for Fendt to read on its terminal.
At this point, I want to express my gratitude to everyone who participated in the discussion and shared their solutions. A special thanks to CommonRail, as I chose to follow his path.
I faced some initial challenges with QGIS and the Next Wayline Converter. Once those were overcome, I converted everything in just a few hours. Now my question to all of you: Is anyone currently in the same situation as I was a few days ago and doesn’t know how to proceed? If so, I would be willing to create a brief guide and publish it as a PDF or a forum post. I would only make the effort in the case of an urgent need, as in a few weeks (no, I don’t know the exact release date :slight_smile: ), an updated version of AOG will be released, generating ISOXML files. This should make things much easier and more straightforward.
Important to note:
- I have only converted the outer boundary and ONE AB line.
- Inner boundaries (islands or other obstacles) are not considered.
- Manual tracing is required in QGIS.
- Only AB lines can be transferred.
- The use of both programs is not self-explanatory
Let me know, and I’ll see what I can do.
So now, Merry Christmas to all of you… or will have… or had!
P.S. Time zones can be headache-inducing :wink:
Release date is fairly soon. The new release will open xml fields with lines and curves. The AOG exports xml fields, lines, and curves.
Yes, I would be interested in the procedure. Thanks
