As for the 6/2 valve commonly used, there’s typically no technical need for it, except as a safety cutoff. If you omit the valve, only technical issue is that to use pressure disengage on autosteer, you need to steer in the opposite direction to the autosteer steering to generate the LS pressure from orbitrol. I was mapping the alternatives, and I think with the 6/2 the safety is not really increased, see attached pdf for the different options.
steering_safety.pdf (37.5 KB)
EDIT 01/12/21 Reupload: steering_safety1.pdf (118.5 KB)
If you have a 6/2 valve in between the autosteer and orbitrol, the safety relies heavily on the 6/2 valve, should the valve remain in autosteer for any reason (spool stuck, electrical fault) there’s no manual steering available. It doesn’t really matter what happens on the autosteer valve side.
If you just omit the 6/2 valve completely and tee directly into steering lines, the failure mode causing no steering is that your autosteer valve spool doesn’t return to the middle when powered off and steering pressure bleeds through the open A/B channels.
So given the above scenarios, the 6/2 valve doesn’t really decrease the failure probability of the system, instead it’s just defined by the failure rate of the 6/2 valve instead of the autosteer valve. With a high quality autosteer valve, you might have actually a lower rate of failure that with some off the shelf 6/2.
Now, if you install a 4/2 cutoff valve to the steering lines, the failure of probability drops, as in order to lose manual steering both the 4/2 cutoff must be stuck open and the autosteer spool not be in the middle at the same time.
So if you have a failure probability of 0.1% on all of the individual valves, both 6/2 and direct tee connection have the same failure probability of 0.1%, but with the 4/2 cutoff, you have a failure probability of 0.0001 %.
Furthermore, bit depending on the autosteer valve type, you will have different amounts of safety built in. With a direct PWM drive, anything that gives voltage to the spools will move the valve. If you on the other hand have a valve with some built-in error control, it will go to a safe mode if something weird happens on the command signals or can communication.
Thoughts?
If you look at Danfoss SIL certified OSPE system, for example, they are using a cut-off spool that cuts off the autosteer valve and the pilot pressure to the autosteer valve, not a 6/2 selector. They also use a steering wheel angle sensor for disengage. When in electrohydraulic mode, the steering lines are just tee’d to the orbitrol.
