Time to draw a coherent picture.
My current process looks quite simple:
- Seeding standard crops (wheat, barley, oats, spelt, rye, beans…) with an old 6 m trailed Horsch DSS at 21 cm row spacing
- maybe pregerm harrow with tractor in the trams
- Following with the interrow hoe some weeks or months later
Hoe shears are 14 … 16 cm, so we have 2 … 3 cm survival margin for the crop - at least in early stage.
The challenge is complicated by undulating sidehills of up to 20 .. 30 percent and most field boundaries far from straight lines.
For hoeing, I still use a venerable Fendt F275GT with the hoe behind the front axle, in direct view.
Precision steering I considered “nice to have” the last years. But sadly , the last F275GT was built in 1984 - more than 40 years ago. There’s no serious successor for it. Some Swiss and Italian manufacurers offer hydraulic driven GT for vegetable gardens in level lands, but their own sales force warned me never to expect the performance, endurance and reliability of a mechanically geared Fendt in continued large hilly operation.
Similiar with camera control: At least 15 years ago, my stated performance goal of 8 km/h at 20 % side hill with 40 cm crop, distorted by wind, was answerd as “ridiculous - impossible” by the salesmen.
At my response “no problem with a GT” I got “Oh, when you have a GT, then there’s no way to sell you a camera…”
In the first step, for seeding only, I’d hope to solve the problem of row spacing between adjacent tracks by reliable RTK cm-level-precision.
When e.g. I target for a 25 cm spacing, I might run a 15 cm knive that does not conflict with the next row at 20 cm and still covers 30 cm spacing at running back and forth.
Here are pictures and discussions what happens when I exceed this margin.
“Account for reduced effective tool width at side hill - #9 by wjr”
To summarize and complete my expectations:
- ± 5 cm precison in 99%. If we take that figurea as 3 sigma, we head for a sigma of 1,5 cm
- reliable in side hills and up to 3m from tree’s canopy
- correction of sidehill and curve errors on adjacent tracks, if they exceed expected errors of 1.5 cm target sigma
- persistence and repeatability of the tracks for subsequent operations
- interactive desktop preplanning of the tracks to balance wedges at nearly-parallel headland, track distance errors and curvy tracks due to undulation and curvy field boundaries
- guiding the tractors steering as slave by the implements position as master to keep mechanics as simple as possible
Scanning the documentation and existing threads, dropping some questions in the Telegram group and here in the forum, I learned that there is little hope that any solution out of the box might fit.
Looks like I have to go the hard way to be able to help out myself.
Let’s start learning.
Along the way, there are some windfall projects and milestones:
- A survey stick similiar to Ardusimple’s for ~ 100 € material
https://www.ardusimple.pl/product/rtk-calibrated-surveyor-kit/
100 € survey stick - A minimalistic setup for lightbar steering at ~ 300 € material
Minimalistic AgOpenGPS test system and lightbar steering for 300 € - A dual antenna UM982 extension for hopefully not much more
Robust dual antenna selection, placment, protection - #15 by wjr - A UM980 base station
Beyond the horizon, I consider to switch to dam farming.
One of my ideas might require to keep front and back tools in sync at ~ 2..3 cm even in curves, changing side hills and changing soil and drift conditions.
No clue yet whether at all and even if, with wich effort this might be possible.
