Hello @baraki
I ordered three valves some time ago. I have not heard anything. Is there production/delivery problems?
Is anyone else having their valves in 2023?
Hello @baraki
Yes, 4 valves this year ![]()
2 here.
Maybe email again. I bet they are really busy with all the orders.
I have sent an e-mail.
Will have to wait for the response.
Spring is already around the corner and would like to be prepared before all the hassle begins.
Wondering if someone could tell me how the baraki closed center Ls valve is electronically wired to the ampseal “All in 1 PCB”? Also wondering whether the “kickout pin” should be placed on “remote” or “pressure”.
Thanks in advance
Nice sheet 1 little comment. Use a relay for lock if you use aio pcb. Less more amps going true the pcb then.
Thanks, excellent diagram. Is it the remote kickout?
Yes exacly
Thats it. ![]()
Why goes the blue line to the Workpin ?
Is it not Pressure Switch?
What size of diode?
Fair point, that was a mistake. I have reported these erroneous diagrams for removal.
Do I have to install a relay on the lock output just because of the width of the pcb trace?
Valves have arrived and quality looks really good!
Thanks Marek! Installation will be done at weekend.
I have a John Deere 6230 Premium i thinking of adding a block on. I need a block for LS.
The problem is that getting to the LS line to the orbitrol is not easy, was talking to a mechanic working for the dealer.
Our idea was to connect it with the lines to the valve block for the front loader instead since they are very easy to access under the right door.
John Deere do also have a 40cm long stretch with hose there between the steel line from the orbitrol to the steering cylinder so its easy to connect to they as well.
Will it work to connect it there or will i get some problems?
It probably won’t work really well because front loader LS is not in the priority valve ls. Specially if you use other hydraulics of tractor for example in u-turn at headland.
Doesnt JD have all the hydraulic lines under the stairs on the right side? Ls p and T and left and right?
I might be wrong. But in my trimble days i have build a few hydraulic valves on some jd and always used those lines.
Could be wrong. More then 15 yrs ago.
You are correct. Thats the lines to the loader block
