Proportional Gain = 8 - 39
Maximum Limit = 110
Minimum to Move = 6 - 38
These work best in boundary contour mode, but none of these are good in AB line or AB curve mode, the straight line always looks like an S
WAS is accurate.
Proportional Gain = 11
Maximum Limit = 110
Minimum to Move = 8
I have noticed that contours tend to steer worse that straight ABs. Probably because because from one point to another there is always an adjustment of angle.
Hello, I installed my non ls valve on my tractor. The steering works well when with the steering wheel. When I turn it on, the wheels don’t turn. the solenoid valves are well supplied and work well. the overflow valve is tightened to 1.6mm. I followed this diagram, what can I do? THANKS
[quote=“HPH, post:466, topic:8011”]
Are you sure you have not mixed the steering cylinder and orbitrol
[/the orbitrol is in the middle (o) and the steering cylinder is on the right (s)?
What happens when autosteer is on, (both cut off valves have 12 V) AND then you press the center of one of the steer valves (with screwdriver or other tool). You can push center about 3 mm in!
