I will try this tomorrow
The stop valves are well lit and the steering solenoid valves light up well too. The steering wheel is stuck but the wheels do not turn
I hopefully only one at a time, I guess you use the manual test function in steer settings.
Yes, one at a time. I use the MA/MB buttons on the cytron
how do i go about ordering a valve?
Use his email.
Baraki mentioned he has problems with too many orders and too little equipment to make more and more valves. But ordered new and things will get better soon. Fingers ![]()
There are 3 connections on the valves for electric, which is GND and which one is PWM/Current?
For both pick one. Does not matter.
Good morning,
can you tell me which 3/2 valve you use to go from manual to automatic and their flow rate please?
THANKS
Which vakve do i need if i have an OC hydraulic system with an CCLS orbitrol an an EF pipe?
Noone answered your question, maybe because you ask about the 2 poppet valves used in the baraki valveblock.
Maybe uou really need 6/2 valve instead?
I use one like this in my first autosteer system.
https://hydrocap.net/en/c/62-magnitno-upravlyavan-klapan-271/6-2-solenoid-operated-valve-dvs6-one-spool-g-1-2-open-center-spool-12-v-82
For most SD2E A3 - 30L flow
For the very large SD2E B3 60L flow
If I understood correctly, you have an orbitrol with a built-in priority valve, such as in the Fendt 300, the OC valve will work well.
Should I build in the valve bevor the orbitrol or after the orbitrol with the EF pipe?
Before orbitrol: pump -------->AS valve-------->orbitrol
I tried to update the Wiki based on all the bits and pieces I could harvest.
If you feel it’s incorrect then drop me a message on telegram or here in discourse and I’ll fix it up.
Very good info!
Now if I could only get my hands on a valve. I’ve been trying to buy one since April 17th.
Has anyone else been able to get one recently?
